12-05-2023 13:42
12-05-2023 13:42
I’ve used other calorie counters from not so accurate much more accurate including the Apple Watch :watch:️ & usually give me calories burned within proximity to each other but this Fitbit is giving me a ridiculous number. There’s no way I can burn 120 calories on a 0.48 mile walk at 12 minutes. It’s usually 30 to 60 calories. Not even the Apple Watch without active calories only turned off will give me this number. There’s no way this can be accurate which is pathetic considering that this is the devices main function. Noticed some snob on another thread telling someone this has no option for active calories only & that why would you question Fitbit 😂. I’m about to return this garbage unless someone can point out a setting I’m missing or something. Thanks in advance.
