Are there any options for Inspire 3 bands?
Hey, I'm looking to replace my Fitbit inspire 3 watchband. The silicone ones are not fun with my skin. It really is uncomfortable. Does anyone know if Fitbit Inspire 2 watchbands fit the Inspire 3? How many mm is the connector part for the Inspire 3 watchband? Do you have any good recommendations for watchbands? Thanks in advance!!
Moderator Edit: Personal info removed
1 REPLY 1
Hi, @amrut627 , I have both Inspire 2 and Inspire 3 and a range of bands for the Inspire 2.  After significant experimentation I have found that all the soft bands (silicone, leather, cloth) made for the Inspire 2 will fit the Inspire 3.  However, none of the hard ones will - so Inspire 2 metal bands, or any band with a metal attachment does not fit - they look like they should, and they almost do (just like the charger for the Inspire 2) - but they pop straight off…
I don’t think I have a device accurate enough to let you know the mm on the attachment, unfortunately.  I can only give you my experience.
I hope this helps.  Welcome to the forums, and please come back and let us know if you find any other tips for Inspire 3 bands.  Lots of people are asking this question!
