06-17-2023
23:12
04:07
06-17-2023
23:12
04:07
Steps over 10,000 reads as 10.5k, 11.2k, etc. can I change it to the full
number? I have the factory clock face.
Best Answer06-18-2023 02:45
06-18-2023 02:45
Hi, @CadillacDeadman , how your stats are displayed is entirely dependent on the clock face that you choose. I would suggest experimenting with different clock faces and see if you can find one that gives you the information that you want.
You can change the clock face in your app, and then sync your Fitbit. The instructions for changing clock face are here
06-18-2023 02:45
06-18-2023 02:45
06-18-2023 04:44
06-18-2023 04:44
Thank you for the suggestion. I appreciate the input.
Allow me to clarify myself.
I'm aware of the multiple clock faces. I like the highlight clock. In the pictures in the clock gallery the highlight clock is shown as listing steps as the format xx,xxx for numbers greater than 10,000. However, I've observed that my particular fitbit shows it at xx,xk, such as 10,3k. I figured since it does not match the pictures something may be wrong. All my units are in imperial, changed the stride settings, and forgot my Inspire 3 on my App and re associated it. I also reset the Inspire 3 on the screen, but will do a clean slate reset with the charger when I get home. Will keep an eye on it as I should see if that worked tonight. If not I may unbox my spare and see what that does.
