02-27-2023
10:28
11:30
JuanFitbit
02-27-2023
10:28
11:30
JuanFitbit
Is there an option to track rowing on my Inspire 3?
Best Answer02-28-2023 04:05
02-28-2023 04:05
Hi, @BdaTim, welcome to the community, you do not mention if you are rowing on a machine or rowing outdoors. While rowing is not specified you should try the following. From the "Today" screen touch your icon in the top left corner>Inspire 3 tile>exercise shortcuts>you are allowed 6, if you already have 6 remove those you do not want by deleting by sliding it to the left.>"+" to add & you will be offered workout and outdoor workout, providing you with the best way forward. I do not row so I'm unable to advise which might be the best choice.
I hope this helps.
Cheers
Gr4ndp4 | UK
