02-18-2025
07:18
06:17
02-18-2025
07:18
06:17
Can the Inspire 3 be downloaded to my PC? If yes how do I do that?
Best Answer02-18-2025 09:51
02-18-2025 09:51
He’ll @CarolMcBride and welcome to the Community. No, that feature is no longer available. You must use the Fitbit app on a compatible Android/iOS smartphone or tablet.
Laurie | Maryland
02-18-2025 09:51
02-18-2025 09:51
Hi, @CarolMcBride, welcome to the community, can you please clarify your question? The "Inspire 3" is the Fitbit device you wear on your wrist or a clip. You need to download the Fitbit app on a mobile phone to operate it effectively The Inspire 3 manual describes how it works. Fitbit Compatible Devices - Help describe the phones that work & the minimum specifications (Note Android GO is not included) You cannot run it on a PC.
I hope this helps but please post here again if we can offer furth advice.
Cheers
Gr4ndp4 | UK
