07-11-2023 13:16
07-11-2023 13:16
Best Answer07-12-2023 08:10
07-12-2023 08:10
@Giorgi757 That's absolutely NOT a Fitbit. No Fitbit screen has a circle like that on it.
Laurie | Maryland
07-11-2023 13:12
07-11-2023 13:12
Can someone help me and tell me which fitbit model this is?
Best Answer07-11-2023 14:47 - edited 07-11-2023 14:47
Hi @Giorgi757 doesn't look like either Luxe or Inspire 3. Fast way to tell what you have - get the Fitbit app and try to set it up. It will ask you which device you want to add and tell you which ones are in range. Much easier. See any markings on the back? If you have a charger and restart the device, it will flash the Fitbit logo, IF it's a Fitbit. Actually, the little thing coming off the device is making me feel it is not a Fitbit product.
07-12-2023 08:10
07-12-2023 08:10
Laurie | Maryland
