Can't connect to help and support
Have been trying to contact help and support for a few weeks.  Every time I try I get "unknown error occurred, Please try again"
Any ideas?
6 REPLIES 6
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or X/Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
Stepping in the U.S.A. since September 2013. Android 14
Thanks. Have text them previously and no problem. But now always has the "unknown error occurred " have tried phone option but same problem. It also appears that they have removed the phone option.  Thanks
From what I've learned being around here, the phones or any of the options to reach support are available when they have people to be there.
I don't think it's an available issue more a connection issue. Every time I try to connect comes up with "unknown error occurred ". Have talked previously and no problem.  But thanks again.
Hi, @Samson24 may I suggest you try this dynamic link "Customer Support" For a prompt response use the Chat facility or phone, it's a good move to note the steps you've taken & the results before contacting the agent so you can brief them clearly. The above link generates different connections depending on your location, it's the same one provided by @Odyssey13
I hope this helps.
Cheers
Gr4ndp4 | UK
@Gr4ndp4 @Odyssey13 Thank you for your help and info shared.
@Samson24 , Thank you for your message. We had an issue with our contact with Support on Jan 29th. This should be solved by now.
If you are still trying to contact Support, here are our available channels
