03-22-2024
10:24
10:32
03-22-2024
10:24
10:32
First of all, I couldn't get this to work via the menu. I was dumbly clicking in all sorts of ways. I solved this by selecting swimming as an activity so that the water lock would automatically start. Now I can't unlock the water lock. I click and click but the clock is locked.
03-22-2024 10:43
03-22-2024 10:43
Hi there, @Faros. Welcome to the Fitbit Community Forums. I'm sorry to hear about the difficulties you've been having while trying to use the water lock feature on your Inspire 3. I will be glad to help you with this.
To turn on water lock, swipe down from the clock screen > tap Water Lock > firmly tap your screen twice. To turn off water lock, firmly double-tap the middle of the screen with your finger. If you don't see "Unlocked" appear on screen, try tapping harder. Turning off this feature uses the accelerometer in your device, which takes more force to activate.
Note that water lock turns on automatically when you start a swim in the Exercise app.
03-25-2024 09:39
03-25-2024 09:39
what setting would you use to track aqua aerobics? I use workout, but the water often affects the screen and ends tracking. I now see there is a water lock feature, but that can't be used with workout. Is there any chance of an update to track aqua aerobics, switching on water lock as it does with swimming? I see lots of other people are haveing the same problem but the thread has been locked for commenting
