02-03-2025
08:46
09:57
DavidFitbit
02-03-2025
08:46
09:57
DavidFitbit
Hello,
I am in a steps competition. Our period of the week for steps is Monday-Sunday. I tried setting my fitbit to Monday but it changes back to Sunday on its own. Anyone else having this issue?
Thanks!
Best Answer02-04-2025 06:58
02-04-2025 06:58
Hi, @topo_chico_tx There are two areas to look at, one should work. In the Fitbit app on your phone touch your icon in the top right corner> Fitbit Settings>Date, time, units>Start week>select Monday>return to the "Today" screen & SYNC. My App is always on Monday. The other setting that might have an impact is the Calendar setting>Click the gear wheel in the top row>settings>slide down>start the week...Monday>I'm not convinced this will make any difference, it's the default calendar setting. Which app are you using for reporting your steps? Does it have a setting of its own?
I hope this helps, please post here again & let us know how you get on.
Cheers
Gr4ndp4 | UK
02-04-2025 06:58
02-04-2025 06:58
Cheers
Gr4ndp4 | UK
02-04-2025 09:40
02-04-2025 09:40
Hey @Gr4ndp4 Thanks for your help. I am currently using the Fitbit app via Apple. I think it worked.
Best Answer02-04-2025 10:45
02-04-2025 10:45
Hi, @topo_chico_tx, I'm pleased you've made progress, if you still have a problem I recommend you post your question on the iOS App - Fitbit Community board as the iOS app sometimes differs from the Android app.
Cheers
Gr4ndp4 | UK
