Charge 6 dismiss a snoozed alarm or change alarm options
Hello,
I just upgraded from a Charge 4 to a Charge 6. When an alarm goes off on the charge 6, pressing the button on the device snoozes the alarm instead of dismissing it. I never snooze alarms have absolutely no use for a snooze button ever. First, is there a way to remove this, or at least make it so I can dismiss the alarm by pressing the button instead of swiping? I use alarms while I'm actively doing other things, so I would like the ability to dismiss an alarm completely without having to look at my watch, otherwise why am I even using my watch for an alarm instead of my phone.
If it's not possible to dismiss the alarm with the button, how do you dismiss a snoozed alarm? When I snooze an alarm, it just shows up in the alarms as snoozed, and the only option I have to make it so it doesn't buzz again when I don't need it to is to delete the alarm, which I don't want to do because I have specific alarms set up.
0 REPLIES 0
