12-07-2022
19:00
13:16
YojanaFitbit
12-07-2022
19:00
13:16
YojanaFitbit
Best Answer12-08-2022 11:04
12-08-2022 11:04
Hello @JaniceM.. since I'm not sure, which post you responded to, I'm not sure what it is that you want to happen.
On the Inspire 3, what type of notifications are you asking about?
Text, emails, maybe system notifications?
Is the issue that the notifications are not removed from the Inspire 3 after you read the preview?
Or do you want the notification removed from your phones notification pannel?
Or do you want the text on your phone deleted after you read the text on the inspire 3.
If you simply read the preview on the watch, I don't believe it will be removed.
If you use the Open or Reply command, the message should be removed from the Inspire 3.
Otherwise, a restart, or after 24 hours, the message gets removed.
Taping Open will open the message on the phones messaging app.
I've also moved your Inspire 3 based post to the Inspire 3 board.
12-08-2022 11:04
