07-17-2023 03:38
07-17-2023 03:38
I have a Ace 3 band and I was wondering if an Inspire 3 will fit in it? It is just a shell and doesn't use the click meganism. I cann't fint any size comparison between these two.
Best Answer07-17-2023 07:48
07-17-2023 07:48
Hi, @Hyrule_Warrior , generally speaking, and with a few exceptions, bands for different Fitbit models do not fit with each other. It is possible that you could get an Inspire 3 into your Ace band, but I would be concerned that if the fit were not exact you would risk losing the Inspire 3 “pebble” (i.e. the device detached from its own band). So I would advise against trying this.
The Inspire 3 is supplied with its own dedicated silicone band. The Fitbit store sells accessory bands and 3rd party bands are also available from other retailers. I would say that getting one designed to fit the Inspire 3 would be a better solution for you.
