11-28-2022
08:30
21:03
YojanaFitbit
11-28-2022
08:30
21:03
YojanaFitbit
I used to have the Inspire 2. I. The watch it had an excercise mode that you could start when working out like weightlifting. I can't find on this one? Anyone with help?
Best AnswerYou need to customize your Exercise Shortcuts on your Inspire 3, just like you did on your Inspire 2. Tap on your profile avatar on your Fitbit app > Inspire 3 tile > Exercise Shortcuts. You will need to remove a shortcut you don’t use in order to add Weights.
Laurie | Maryland
Laurie | Maryland
I just got an Inspire 3 after years of using an Inspire 2. When I go look on my device or when I go to "Exercise shortcuts," the "Weights" option no longer is there. I just have "Walk", "Run", "Bike", "Swim", "Workout", and "Treadmill". Where did "Weights" go?
Best AnswerHello @passthemash and welcome to the Community. Your Inspire 3 shortcut list is its default, preloaded list. Your list from your Inspire 2 doesn’t carry over. You need to remove a shortcut that you don’t use in order to add Weights. You can also customize the order of your shortcuts there.
Laurie | Maryland
Best AnswerThank you! I had always misread this section and thought the 6 in view were the only ones available (weights showed up by default on my Inspire 2). Now I've fully customized it 😊
