04-26-2023 20:41
04-26-2023 20:41
My new Inspire 3 Fitbit doesn’t wake up when I raise my wrist. I’ve tried different solutions but they is no place displayed on the watch face for setting this. Any intel appreciated.
Best Answer04-26-2023 20:55
04-26-2023 20:55
2 possibilities, both easily found in Quick Settings by swiping down from clock screen.
Most likely, you accidentally have Auto Wake turned off; other possibility, in Sleep Mode which prevents screen turning on with wrist turn.
From Inspire 3 manual
04-27-2023
10:27
10:49
04-27-2023
10:27
10:49
@JohnnyRow Thank you for your help and tips.
@Expatri8 , A warm welcome to the Community !Thank you for your messages.
Just adding to the tips from our friend JohnnyRow . On the Quick settings also make sure that the Inspire 3 is set to be worn On Wrist and not On Clip.
To change any setting there, just tap on it.
