05-06-2024 11:24
05-06-2024 11:24
My daughter hasn't synced her inspire 3 to her phone for 25 days. When we try and do it now it doesn't work
We have:
Checked app and phone software is up to date
Restarted phone
Restarted fitbit
Deleted the the tracker as a device in the app
Uninstalled the app
Reinstalled the app and now when trying to add the device it gets stuck on connecting. I get as far as entering the 4 digit code off the fitbit into the app then it just gets stuck and says
Setup is taking longer than usual.
Device is only a few months old.
Can anyone help
05-06-2024 11:50
05-06-2024 11:50
No help. I just have the same problem. Now the phone isn't even detecting the Inspire 3 after I unpaired and tried to reinstall. I don't even get the 4 digit code.
05-06-2024 12:13
05-06-2024 12:13
Syncing the Inspire 3 device to the phone can be very problematic but, if you actually got to the point of entering the 4 digit code and it failed there, then I would suspect an issue with the Bluetooth module in the device.
Have you tried to start the setup process completely over yet?
05-06-2024 12:15
05-06-2024 12:15
05-06-2024 12:20
05-06-2024 12:20
Try the complete sequence above to see if that helps.
The app has known issues with syncing to Fitbit devices, so it takes a few tries at times.
05-06-2024 12:52
05-06-2024 12:52
Interesting. I seem to recall a post from one of the moderators with this suggestion, so there must be something to it.
