After 4 days of being unable to sync and following the troubleshooting steps on this forum I was forced to reset my user data losing the final days of the month so crucial for the premium sleep report.
very annoyed.
but the fitbit will sync again.
Best AnswerHi, @Gnosh, welcome to the community, I trust you will not find yourself in the same position again. If you do your first step will be to restart your Inspire 3, provided you do not use the factory reset you will not lose your data.
How do I restart my Fitbit device? - Fitbit Help Center describes the process.
If you have difficulty syncing refer to this article Why won't my Fitbit device sync? - Fitbit Help Center
I hope this helps.
Cheers
Gr4ndp4 | UK
