05-21-2023 17:42
05-21-2023 17:42
I forgot my watch home.
it is supposed to go off at 7am every monday.
will it stop after a few minutes or will it snooze/vibrate forever ?
(Another way to ask this is : will my neighbours want to kill me?)
05-21-2023 18:04 - edited 05-22-2023 11:29
@Maauvp , A warm welcome to the Community! Thank you for your message.
Don't worry about the neighbour, the alarms are silent, and only vibrate. Depending where you left it, the vibrations might be felt harder.
The Alarm will go off and will vibrate for about 2-3 minutes. Then it will go silent again (snoozed) for 10 minutes. Afterwards it will vibrate again for about 1-2 minutes again.
This should stop after 2-3 times that the alarm is not turned off. But will repeat everyday that you have the alarm set, until the battery is consumed.
So your neigbours won't notice it , unless the table, surface where the tracker was left, does vibrate also with the tracker .
05-21-2023 18:23
05-21-2023 18:23
Thank you! I can live with 2-3 times! Thats better than 25 🥲
