06-03-2025 14:50
06-03-2025 14:50
After a recent firmware update my Inspire 3 shows my heart rate to be under 100 bpm when exercising, barely peaking at 90. A few days ago the same exercises put my heart rate well over 120. No change in how I wear my device.
Best Answer06-03-2025 20:36
06-03-2025 20:36
It's good to see you participating in the forums @mattbrat1.
Thank you for taking the time to share the information regarding this difficulty with your Inspire 3.
I'd recommend restarting your Inspire 3. For more information, see How do I restart my Fitbit device?
If the above doesn't help, I'd suggest resetting the heart rate settings by following the steps below:
Best Answer06-04-2025 05:43
06-04-2025 05:43
@mattbrat1 Firmware version 210.26 changed the heart rate algorithm. Help article I'm not sure the moderator's suggestions will help you.
Laurie | Maryland
Best Answer06-04-2025 06:34
06-04-2025 06:34
Thanks for confirming that. When running for at least 20 minutes, it tracks well. For other exercises, like weights, pull-ups, push-ups, etc., it was barely tracking any increase in my heart rate. I wear the device as recommended, a finger or two above the wrist, with a slightly tighter fit when exercising. I've followed the advice to turn heart rate on/off, sync, and restart. Hopefully, that will provide some consistency.
