05-26-2025
08:12
08:42
05-26-2025
08:12
08:42
After the upgrade my fit bit face won’t light up and the “receiving” lights on the flip side do not light up. I have tried resetting, allowing to completely drain the battery and recharging. I can’t see the face to reset that way. Any ideas?
Best Answer05-27-2025 07:39
05-27-2025 07:39
@tfetzer Thanks for getting back to me and for the details provided.
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer05-26-2025 08:53
05-26-2025 08:53
Hi there, @tfetzer. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 stopped showing the LED lights on the back after the update. I understand your concern, I will do my best to help you with this!
If you haven't done so yet, I'd recommend resetting the heart rate settings on your Inspire 3 by following the steps below:
Best Answer05-26-2025 14:55
05-26-2025 14:55
Hi!
Thank you so much. The fit bit screen will not light up at all although it vibrates. I can’t do anything on the face it won’t wake up. I have tried to reset it from the charger etc.
05-27-2025 07:39
