09-02-2024 05:51
09-02-2024 05:51
I had this issue where sleep stage was not shown and it was just the "Awake, Restless, Asleep" screen everyday in August, until i decided to turn off sleep mode set from 10pm-4am and kept it to DND instead.
Hope this might help if anyone is facing the same issue. Cheers !!
09-02-2024 08:05
09-02-2024 08:05
Would you please elaborate more about exactly what you did to get sleep stages working for you? Do you also get Heart Rate Variation and Breathing Rate heart metrics returned now as well?
I almost always get sleep stages and all 5 heart metrics returned every day, but my wife never does and nothing that I've tried to get that working for her has worked so far.
09-02-2024 08:26
09-02-2024 08:26
In August, I only had 3 days where sleep stage was shown, I was even told I will be provided a replacement, but as a last resort I disabled Sleep Mode (Settings>Quiet Mode>Sleep Mode>Schedule) and every night before sleep, I kept it in “Do Not Disturb” and turned off “Auto Wake”.
For the past 3 days I have been getting all the metrics including HRV and BR.
You can try this if not done earlier.
09-02-2024 10:04 - edited 09-02-2024 10:05
Thanks for the additional information, I will definitely try using DND mode to see if that helps.
I've seen some posts on this forum suggesting that allowing the Inspire 3 to automatically detect when sleep starts is more reliable than using the sleep schedule to get sleep stages, so maybe that worked for you. DND mode could only help with that.
