05-02-2025 12:04
05-02-2025 12:04
Sooo another complaint
Why do you have to do 9 hours straight of movement. If you move for 8 hours then sit down to tea then start up moving again in hour 10 , no matter what you do it dosnt count anymore movement, why does your movement have to be constant and consecutive why can't it count any 9 hours in a day why does it have be 9 hours in a block . It makes the stat useless and nonsensical.
Best Answer05-03-2025 06:28
05-03-2025 06:28
@Idriscadras I understand that you are just venting, but I want to clarify some things for you. I think the 9 hours might be a default setting. You can set your time frame from 5-14 consecutive hours. This feature has been around for a long time. I used it on my Fitbit One. It has always been consecutive hours, with no plans to change it. It is supposed to be a gentle reminder to avoid being sedentary.
Laurie | Maryland
