06-03-2024
23:31
10:37
06-03-2024
23:31
10:37
Title. Lost my Fitbit. Downloaded some ‘Fitbit tracking’ apps and supposedly it’s in the room with me … is there a way I could set an alarm from my phone on my Fitbit? So annoying. I was up and down all over the house today so I def put it in an unlikely spot. I’m sure it’ll turn up when I don’t actively look for it, but is there ANY way to help find my Fitbit? It’s kinda like a part of me like my phone is now. I don’t like being without it
Best Answer06-03-2024 23:59
06-03-2024 23:59
Hi @vijayubha alarms are set on the device, not the app. BUT......if you have notifications set up, try sending yourself a text or have someone call your phone. If it's on a hard surface or a piece of paper, it rattles when it gets the notification. You must be within 25 feet of the device, so walk around the house and see if you can find it that way.
06-04-2024 06:28 - edited 06-04-2024 07:44
The Bluetooth radio connection range between your phone and Inspire 3 device is only about 30 - 40 feet, so you can use that knowledge to reduce your search radius by trying to sync your phone to the device while looking for your Inspire 3 device.
If the Inspire 3 device is out of range from your phone, you won't be able to sync the device with your phone. However, when you get within range of your Inspire 3 device, you will be able to sync the device with your phone.
