How can I locate my lost Inspire 3?
Lost inspire 3. Still has charge. How can I fined it
6 REPLIES 6
Hi @Casnlile     This Help article  has advice to help you.  If you can sync your Fitbit, it’s within about 30 feet.
Laurie | Maryland
It has steps, not many, so I think I lost it and someone else has it. Sends
me notifications to allow random ….stills shows % of time left.
@Casnlile   If you can see the current battery level, then it is nearby and syncing.  What do you see when you tap on the device/battery icon in the upper left of your Fitbit app?  Does it show the time it synced last or that it is looking for it?
Laurie | Maryland
Hello @CasnlileWelcome to the Fitbit Community! It's great to have you here!
Thank you for letting us know that your Inspire 3 is showing steps on the app.
According to what @LZeeW told you, since your Inspire 3 is showing footsteps, this means it's nearby, so you can check under a sofa or your bed, as it might have fallen. Additionally, try using Bluetooth trackers; select the appropriate one for your phone below: For iPhone, try LightBlue Explorer. For Android, try Bluetooth Finder
Thank you @LZeeW for your support.
It says connected 12% battery. Will it sync if it’s not in my area.
@Casnlile   Please tap on the device/battery icon.  If your Inspire 3 tile says Looking, then it is out of range.  If it shows a recent sync time, then start looking in pockets and under couch cushions, because it is nearby.
Laurie | Maryland
