How can I remove dust from Inspire 3 ?
The dust caught in the cracks surrounding the display is increasing, and I am frustrated because I cannot remove the dust. This body seems to be inseparable, so how do you manage it?
2 REPLIES 2
Hi @hwiui  use a soft toothbrush and see if that helps. I'm not sure using canned air would be a good idea, but you could try that. Some people use a toothpick or a cotton swab to clean, too.
Stepping in the U.S.A. since September 2013. Android 14
Welcome to the Fitbit Community, @hwiui. Thanks for sharing your Inspire 3 cleaning query.
Please follow the advise of the help article: How do I clean my Fitbit device?
Thank you for your comments and advise @Odyssey13
