02-20-2025
04:00
06:15
02-20-2025
04:00
06:15
How do I enlarge time on my Fitbit? Since recharging it’s gone really small
Best Answer02-20-2025 20:43
02-20-2025 20:43
Hi, @Olibug , unfortunately the Inspire 3 does not have an option to enlarge the typeface on the device.
However, different clock faces have different sizes and configurations on the clock screen, and hopefully you can find one that suits you. You can change the clock face in your app, and it is there that you can see all the available clock faces - so you will be able to all your options there. Instructions for viewing and changing the clock face on your Inspire 3 are here . Be sure to sync your Fitbit whenever you make any change in the app.
Just in case something has gone wrong with loading your clock face following the update I would suggest that there are two things you could try. I would suggest changing your clock face as per the instructions above, syncing your Fitbit and confirming the change, and then changing back to your originally preferred clock face to see if the original typeface size is restored. You could also try giving your Fitbit a restart . If neither of these steps solve your issue then it sounds like the new update is not compatible with your originally chosen clock face. This can happen where the clock face is a third party option (in that case Fitbit cannot confirm that it will continue to work with updates). In that case I am afraid that my first suggestion - to chose another clock face - is likely to be your only option until the third party developer posts an update compliant with Fitbit’s!
I hope this makes sense and helps you find a solution. Welcome to the Community Forums!
02-21-2025 07:02
02-21-2025 07:02
Can you post a picture of how your Inspire 3 screen looks?
Best Answer02-22-2025 10:33
02-22-2025 10:33
I don't think you can zoom in- maybe try changing a clock face?
