08-02-2023
18:50
09:39
08-02-2023
18:50
09:39
I do gymnastics but every time I do it I have to put it in workout. Is there a gymnastics exercise shortcut?
Best Answer08-03-2023 02:39
08-03-2023 02:39
Hi, @Bella_P , there is not a specific gymnastics shortcut, however it is in the Fitbit database. So you should carry on tracking your gymnastics session as a “workout”. However, once it syncs to your Fitbit app, simply go to the exercise tile in the Home Screen and then click on your “workout” to open the details. If you use iOS you will see “Categorize exercise” near the top of the screen. In the next box start to type “gymnastics” and it will pop up. Select it, and your session is saved.
Android works almost the same, except when you click on your workout you will see a pencil icon - click on that and you will also have a search box to categorize your session.
If it sounds complicated it is only because I have written out all the steps. It takes literally seconds and then you will have a full record of your activity!
I hope this helps. Welcome to the forums!
