02-22-2023
19:46
06:29
02-22-2023
19:46
06:29
Is there a selection for tennis in the exercise choice? If yes, how do I load it?
Best Answer02-23-2023 03:28
02-23-2023 03:28
Hi, @Eljaycee , welcome to the community, you can select "Tennis" by adding it to the "Shortcuts" feature. From the "Today" screen touch your icon in the top left corner>Inspire 3 tile>exercise shortcuts (right at the bottom)>you can only have 6 shortcuts so will need to delete one if you already have 6>"+" in the top right corner>Tennis>add to Inspire 3>return to the "Today screen & sync by sliding your finger down the screen & releasing. Go to your Inspire 3>swipe left from the clock face two icons then swipe up to see "Tennis". If you want to change the order of the exercises in the shortcut feature return to the exercise shortcuts screen in your Fitbit app and you can change the order by dragging & dropping as desired.
I hope this helps, let us know how you get on.
Cheers
Gr4ndp4 | UK
