08-23-2023
13:42
07:36
08-23-2023
13:42
07:36
my replacement for inspire 3 , can not add water aerobics I have tried adding it to Excercise shortcut . It says I can select 2 more activities but it is not allowing me to add it. The list does not have WATER AEROBICS . What to do.? I purposely purchased this fit bit for that reason, my original fit bit had it.
08-24-2023 14:05
08-24-2023 14:05
I have inspire 3 & do water aerobics too. I set it to 'workout' mode when I do water aerobics, but find that it turns off randomly and doesn't accurately track the entire time I'm in class. What to do?
Jean
08-24-2023 15:45
08-24-2023 15:45
@JeanEB if you use workout mode the touchscreen isn't locked and water will interact with screen. That's why is turning off randomly. There is no fix for that. You may track it as Swim but that isn't going to provide much of data if you don't actually swim laps. For water activities, Fitbit isn't a good choice.
