How do I turn off notifications on my Inspire 3?
I am having difficulty shutting of notifications on the Inspire 3. I have followed the instructions given in these forums...and no dice. I have literally said "no" to every possible notification...and I still get notifications of every variety: text, email, doorbell.
3 REPLIES 3
The one thing I want my Fitbit to 'notify' me is of calendar appointments on my Outlook calendar. Anyone know how to do that? (and turn off all the other notifications which seem impossible to stop).
Hi @JeffDD  the Fitbit help article shares how to turn on those notifications. Have you tried doing the opposite in order to stop those notifications? I had to tell my Android phone what I wanted as well as the Fitbit app. See if anything in that article helps you.
Stepping in the U.S.A. since September 2013. Android 14
The notifications feature is a little confusing to toggle. Tapping on your profile picture to get to the settings will allow you to turn off the app notifications, but to turn off notifications to your watch, you have to access the settings by tapping the battery percentage and clicking your device. Make sure you have accessed the notifications option through the battery percentage. Then, if you want to only receive Outlook notifications, make sure Mirror my phone is off. Then turn Calls off, and click into Emails and Texts and turn them off. Then set Calendar notifications to Outlook. If Outlook doesn't appear, turn Calendar notifications off and select Outlook in App Notifications. Whether or not you're selecting Outlook in App Notifications, make sure all apps except Outlook are turned off.
Hope this helps!
