01-07-2023
12:49
21:35
YojanaFitbit
01-07-2023
12:49
21:35
YojanaFitbit
How do I increase my water intake goal on my Inspire 3?
Best Answer01-10-2023 10:28 - edited 01-10-2023 12:11
@Merewisp Thank you for getting back to me. If you're using an iOS device: Open the Fitbit app > tap on your 'Profile picture' > tap on 'Activity & Wellness' > tap on 'Nutrition & Weight' > tap on 'Water' and change your water daily goal. Remember to sync your Fitbit at the end.
Best Answer01-09-2023 21:14 - edited 01-10-2023 07:32
Hi there, @Merewisp. Welcome to the Community Forums.
Thanks for posting your inquiry. You can edit your water goal in the Fitbit app > tap on 'Water' tile > tap on gear icon at the top > tap on 'Daily water goal' > Tap 'Save' and sync your Fitbit.
For more information about water intake, see How do I add, edit, or delete Fitbit data and activities?
Best Answer01-10-2023 08:05
01-10-2023 08:05
Thank you Yojana for your reply! I've done as you instructed but there is no gear icon on the page. Any insights?
Best Answer01-11-2023 10:49
01-11-2023 10:49
Thank you so much for your guidance!
Christine
