I've tried everything I've read online to turn off Active Zone Minute alerts on the Inspire 3.
I am deleting this post.
1 REPLY 1
Hi, @SunsetRunner , turning off AZM notifications on your Inspire 3 should do the job.  I would try going back to that setting and turning AZM notifications to ON, then sync your Inspire 3 with the app.  Once it has synced, go back to the setting on your Inspire 3 and turn it OFF and sync your Inspire 3 again and see if that helps.
Also in the app, generally speaking in order to suppress a notification that you have achieved a goal you want to set the goal as high as possible rather than as low as possible.  So for your AZM daily and weekly goal I would put in the highest number it will accept - if you don’t achieve your goal you won’t get congratulated on it.
