10-02-2022
01:27
16:38
YojanaFitbit
10-02-2022
01:27
16:38
YojanaFitbit
How long is the maximum screen timeout? I need a clock with seconds to be visible for more than 15 seconds.
I believe the always on display removed the seconds from the clock faces- is that correct?
Best Answer10-07-2022 06:37
10-07-2022 06:37
Hello @Catvet1
You can find and adjust the screen timeout in the settings of the Inspire 3. Just swipe down on the clock face then scroll down to and tap display. Now scroll down to and tap screen timeout. Here you can adjust the amount of time.
You’ll find this YouTube video helpful: https://m.youtube.com/watch?v=vepr7DxV8t4
😃 I hope this helps and provides you with an answer to your question. Please let me Know if this helps
10-07-2022 06:37
10-07-2022 06:37
Hello @Catvet1
