02-20-2023 10:10 - edited 02-20-2023 10:13
Im creating a new topic because the other one is old and has a green check mark already.
I purposely bought an Inspire 3 because it’s the only Fitbit I can wear in my pocket. This is important for me working in health care.
However I simply can’t deal with constant scrolling text reminding me it’s “clipped on my body”. Not only is it obnoxious but it is replacing the Date on my screen.
I can’t even have a Time/Date/1 Stat display in clip mode because of this. That is unacceptable. It blows my mind there is no way to turn off the scrolling text. I’ve never seen that on any Fitbit before. If this can’t be turned off I’m just going to return it and continue using an old Inspire 2 that doesn’t have obnoxious scrolling text.
Best Answer02-20-2023 10:25
02-20-2023 10:25
Hi, @bhalv, welcome, you are of course using your Inspire 3 as intended in the clip (I assume you have a clip and your device is mounted in it). For clarity from the clock, the screen swipe down to "worn on the wrist" and tap the icon which will change to "clip on body" swipe up & touch "yes" swipe up to get the clock screen again with the time etc. The blue legend reminds you it is set to "clip" but you should still be able to see the time & other data depending on the clock face you are using. If the appearance is not to your liking try some of the other clock faces, as you know when the device is set to "on clip" you will not get HR and related data.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer02-20-2023 11:15
02-20-2023 11:15
Is there any possible way to remove the blue scrolling reminder? It is obnoxious and I don’t need it.
15:15
11:11
02-20-2023
15:15
11:11
@Gr4ndp4 , Thank you for your help and infos.
@bhalv , A warm welcome to the Community! Thank you for your messages and feedback. I get where you come from.
The "clipped on my body" text was implemented with the clip feature, as on older models, users couldn't notice on what mode the tracker was set.
As you already know, some features turn off when on Clip mode. This banner cannot be turned off.
We're constantly striving to improve Google and Fitbit products and services, and we appreciate all of the input we receive from our customers. The best place to make your voice heard is the Feature Suggestion board on our community (community.fitbit.com/t5/Feature-Requests/idb-p/features).
If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
Thanks for your feedback and for participating in our community!
