08-03-2023 06:42
08-03-2023 06:42
My inspire3 does not vibrate when I get a call on my mobile even though the right setting is on. Does anyone have any advice? Thanks
Best Answer08-06-2023 09:17
08-06-2023 09:17
Hi, @Ziney welcome to the community. It might be possible you are not feeling the vibration from your alarm, on your Inspire 3, from the clock screen >swipe down to and touch settings>swipe up to vibrations and set to strong>swipe down to quiet more and ensure you do not have DND, sleep schedule or exercise focus engaged.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
08-07-2023 09:37
08-07-2023 09:37
I have the same problem. My relatively new Fitbit Inspire 3 has stopped vibrating when I get a phone call. Nor does it vibrate ten minutes before the hour when I have not completed 250 steps. Where can I find the settings for these problems?
Savtadina
Best Answer08-07-2023 10:05
08-07-2023 10:05
Hi, @savtadina, welcome to the community, have you checked the settings described in my earlier message?
Let us know.
Cheers
Gr4ndp4 | UK
Best Answer08-13-2023 04:52
08-13-2023 04:52
Hi @Gr4ndp4 I am also facing the same issue in my new inspire 3, not getting any vibration for alarm or call.Already checked settings that sleep mode, dnd or quiet mode is off.
Best Answer08-13-2023 15:24
08-13-2023 15:24
Thanks! I had not read this before. I just tried it and put the vibrate setting on strong. I hope it works.
Best Answer08-15-2023 03:58
08-15-2023 03:58
Hi @savtadina is it started working for you ?
