11-22-2023
12:09
17:11
JuanFitbit
11-22-2023
12:09
17:11
JuanFitbit
Since mid October my fit bit is not recording my sleep I am only getting simplified data. Nothing has changed and yes I have tried all the re sets.
@paula2000 , A warm welcome to the Community ! Thank you for your message and efforts.
I assume that the heart rate is being recorded and the green LEDs are blinking.
If not please verify on the quick settings, that the Inspire 3 is on wrist mode and not on clip mode.
The following conditions can prevent sleep phase recording:
- You record your sleep using the app instead of the tracker's automatic sleep detection.
- The tracker's battery is almost empty when you go to bed (below 25%). This prevents the pulse from being recorded regularly.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on the wrist. You should be able to put your index finger between the bracelet and your arm without much resistance so that your pulse is recorded regularly and sleep phases can be recognized.
@paula2000 If your heart rate is not being recorded, you can check that your Fitbit is set to “On wrist” otherwise the heart rate is automatically turned off. Swipe down from the clock face and make sure it says “on wrist”.
You can also check that heart rate is not turned off. Swipe down to the settings menu, tap to open, then swipe up to find heart rate and make sure it is turned on.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
