01-03-2025
03:45
08:26
DavidFitbit
01-03-2025
03:45
08:26
DavidFitbit
Every morning, I am tracking my rem sleep, and it is no longer reflecting on my inspire 3 this morning
Best Answer01-14-2025 09:40
01-14-2025 09:40
Every morning I track my REM and DEEP sleep, This morning, it was no longer giving me any of that info. WHY???
Best Answer01-14-2025 11:41
01-14-2025 11:41
@Vjrobinson @Susieq97446 , A warm welcome to the Community! Thank you for your messages.
The following conditions can prevent sleep stages from being recorded:
- You record your sleep using the app instead of the tracker's automatic sleep detection.
- The tracker's battery is almost empty when you go to bed (less than 25%). This prevents regular heart rate recording.
- You use the metal bracelet while sleeping
- You sleep less than 3 hours.
- The bracelet is too loose or too tight on your wrist. You should be able to put your index finger between the bracelet and your arm without much resistance so that your heart rate is recorded regularly and sleep phases can be recognized.
01-14-2025 12:01
01-14-2025 12:01
Best Answer01-14-2025 12:56
01-14-2025 12:56
@Susieq97446 Thank you for your message.
If you haven't done so yet, try restarting the Inspire 3 .
Try wearing the tracker on the back side of your wrist during the sleep. Here it is easier to track the heart rate.
Best Answer01-14-2025 17:40
01-14-2025 17:40
