09-16-2022
23:09
22:31
YojanaFitbit
09-16-2022
23:09
22:31
YojanaFitbit
I have upgraded from an Inspire HR to the Inspire 3. Have noticed the vibration intensity of the alarm app is noticeably less than the HR.
Would be great if this was improved as silent alarms are valuable. Thanks
12-04-2022 16:50 - edited 12-04-2022 16:51
Hi there, @Peter.H and @Archaicertes. Welcome to the Fitbit Community Forums. @fnrhrfjfjrj Nice to see you around.
I really appreciate your feedback. Can you please confirm if you have changed vibration strength on your Inspire 3? You will find the instructions on Fitbit Inspire 3 manual, page 21.
Hope this helps.
09-18-2022 22:09 - edited 09-18-2022 22:11
I just overslept an hour because I slept through the alarm. That never happened for the Charge which I have used in this way for a year. It gives a buzzing sound like a fly but the vibration can hardly be felt. I also don't notice the difference between normal and strong vibration.
12-04-2022 13:16
12-04-2022 13:16
I had inspire 2 and I continually sleep through the inspire 3 alarms. I even tried the smart wake as well. I never had this problem before. It is now useless and I have to use my phone alarms.
Hope this helps.
