04-16-2023
15:57
06:03
04-16-2023
15:57
06:03
Help, I have a Inspire 3 and a Charge 5, both of them stopped syncing recently.
I have tried everything so I removed the device and tried to add it again but neither one will get past the passcode on any of my devices. I have tried:
Resetting fit bit
Let battery die completely on fitbit
Re-installed fitbit app
Factory reset a phone out of desperation
Tried multiple times.
Walked in a circle chanting to random gods for help.
Neither device will let me get past the passcode part, I enter the code, both devices say connecting then just end up timing out.
I have tried a Note 9, Note 10, Note 10, Huawei P30, Samsung Tab S8, S7.
This is beyond ridiculous I don't even know how to respond anymore other than through the pieces of #### out and warn my friends to never get one.
Update: Other Note 10 was supposed to be Note 20
04-17-2023 06:48 - edited 06-19-2023 04:08
Hi there, @Phunction. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Inspire 3 before reaching out. I understand how you must be feeling.
Note that you can't connect multiple devices that use an app gallery to one account. For Fitbit Charge series, Fitbit Ionic, Fitbit Inspire series, Fitbit Luxe, Fitbit Sense series, Fitbit Versa series, and Google Pixel Watch, only connect one of these devices to your account at a time.
With the above being said, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Inspire 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
As a friendly reminder, please note that you can any mobile device. Nevertheless, bear in mind that your Luxe can only talk to one device at a time. It can be trusted on many devices, phones, tablets, and so on, but because of the limitations of Bluetooth, it will only be able to talk to one at a time.
The data from your Inspire 3 is sent to the Fitbit cloud. After the data has been processed it will be put into your Fitbit account. Now your Fitbit account has access to and will display the data. Opening the app on a second device/phone/tablet will have access to the same data and a sync is not needed if a sync recently occurred through a different device.
Best Answer04-17-2023 06:48 - edited 06-19-2023 04:08
