12-03-2022
07:56
11:46
YojanaFitbit
12-03-2022
07:56
11:46
YojanaFitbit
I’m very disappointed in the Fitbit inspire 3. I just purchased and once I received it I realize that NONE of the 10 or more bands I have for my prior Inspire HR are compatible. I like to chg bands often. Also the plastic bands that come with the Fitbits break very easily after a few months of use. I must be able to purchase a good quality band that doesn’t break easily. This is a lousy, poor decision on the part of the Fitbit design and marketing teams! I am returning the Fitbit and I’m now considering looking at other brands.
Moderator Edit: Clarified subject and word choice.
12-09-2022 11:45 - edited 12-09-2022 12:02
Hi there, @cgx. Welcome to the Fitbit Community Forums. I really appreciate your feedback about Inspire 3 bands. Sorry we don't have this option for you.
As you can see on Inspire 3 manual, it's mentioned that Fitbit Inspire 2 bands and clip accessory are not compatible with Inspire 3. And the Inspire 2 charger doesn't work with Inspire 3 either. This information is on page 6 and 13. We don't specifically mention Inspire HR since it is an older model and those type of bands are not being used any more on recent models since Fitbit technology is always innovating.
Thanks for your understanding.
12-10-2022 12:57 - edited 12-10-2022 12:59
But why? It's not definitely not innovation. Anti-consumer, regressive practices like usual for Fitbit.
12-11-2022 20:12
12-11-2022 20:12
Nice to se you around the Fitbit Forums, @Runner1255.
Thank you very much for taking the time to provide your feedback as that helps to continue working on improvements to our services and features.
12-22-2022
00:03
09:51
YojanaFitbit
12-22-2022
00:03
09:51
YojanaFitbit
This has absolutely nothing to do with Fitbit's continuing innovating technology. The outside form factor has nothing to do with the internal guts of the device, it's just a piece of plastic. It's just a way to gouge the customer. That's why I use either eBay or Amazon to get the cheap bands from China.
They have been doing this for years. Please do not disrespect your customers with the innovation excuse. It's unseemly.
Moderator Edit: Formatting / Word choice
12-23-2022 10:01 - edited 12-23-2022 10:04
@bartonmaru Sorry you feel that way about this. I appreciate your feedback. Please know we'll keep working to improve our devices and accessories, as well as the experience with them.
04-18-2023 12:25 - edited 04-18-2023 12:26
A bit late to the party, but my old original Inspire 1 band does fit in the Inspire 3. I was a bit disappointed at first when I heard old bands won't fit, but I figured I would see for certain that it didn't fit, but lo and behold, it does fit. Even with the original pins. So it won't hurt to try some of your old bands to see if they will fit. It does take a little finagling to get the pins to set in the hole, FYI. Work over a white towel, so you don't lose the pins.
07-10-2023 15:47
07-10-2023 15:47
That’s not true. The band for the Inspire 3 is EXACTLY THE SAME BAND as the Inspire HR! And I’m pretty mad about that since my old HR broke off at the band connection which was a common problem. I had assumed that the new Inspire would have a completely redesigned band. Very very disappointed in this.
