02-17-2023
01:19
08:49
02-17-2023
01:19
08:49
My brand new Inspire 3 charger won’t stay connected. It looks like it’s connected but when I let go it pops off.
02-17-2023 04:08
02-17-2023 04:08
Hi, @AlaskaLaura, welcome to the community, the Inspire 3 charging cable is not reversible, you should check the two spring-loaded pins in the charge cable puck are aligned with the 4 contacts, locate the little plastic horn next to the pins into the pebble aperture and push the charging puck onto the Inspire 3 pebble, you will hear a click and find it is firmly fitted (as demonstrated in this video at 3.41). It is not held in place by magnets like some other Fitbit devices. To remove the charging cable you need to give it a firm tug.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer02-17-2023 07:21
02-17-2023 07:21
02-17-2023 09:38
02-17-2023 09:38
Hi, @AlaskaLaura, thanks for the feedback, I think your best way forward is to talk to "Customer Support" using the phone or chat facility for prompt attention. Make a note of the steps you have taken & the results along with the date you bought your device and the seller. This will allow the agent to deal with your issue quickly.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer02-17-2023 09:54
02-17-2023 09:54
