05-11-2023
03:11
10:44
05-11-2023
03:11
10:44
I got an inspire 3 and the belt clip from Fitbit but the device keeps falling out. The silicone is not stretched or worn and I am seating it securely, but if I keep realizing it is not there and have to go through the painful process of finding it. This is just during simple activity like yardwork and light calisthenics. It has only happened at home and seems mostly ok just walking. Are there better clips? Soon I am going to end up losing it and not being able to find it.
Best Answer05-11-2023 10:05
05-11-2023 10:05
Hi, @prem0069, welcome to the community, there are alternative clips available on Amazon & Ali Express. I do not know if they are any good, perhaps someone with experience of these clips will drop by. Your problem is not something I've seen commented on in the past, you might experiment by wearing it inside your clothing so if it comes out again you do not drop it.
I hope this helps.
Cheers
Gr4ndp4 | UK
05-11-2023 10:05
05-11-2023 10:05
I hope this helps.
Cheers
Gr4ndp4 | UK
