01-18-2024 20:27
01-18-2024 20:27
How can I put the inspire 3 in clip mode? I’m only seeing a choice for which wrist I wear it on. Thanks!
01-18-2024 22:04
01-18-2024 22:04
Hi @lareab everything Inspire 3 can be found here - click to go there. You'll find more info on the clip feature on Pages 20 and 21 of the user manual, which is linked in that area. You have to make the change from wrist to clip on the device settings.
01-18-2024 22:04
01-18-2024 22:04
01-20-2024 11:41
01-20-2024 11:41
Here’s the reply I would have liked to receive: There is not a setting for this in the app. Scroll up to access settings on the device, and you will see the option to set it to clip mode.
01-20-2024 11:48
01-20-2024 11:48
I am so annoyed with this forum. First, there are not any answers in the questions I searched. just a link to the manual. Your link was at least better as it didn’t require login. Then there was a box with a check in it and I wanted to uncheck it - instead it resulted in this non answer being chosen as best answer. Maybe you’ve been told not to actually answer anything?
01-20-2024 23:33
01-20-2024 23:33
@lareabas a volunteer on the forums, I find it best to give a link to the information so the one asking for information can see it for themselves. Sometimes all it takes is for someone to know where to find the area for their specific device.
