03-04-2025
17:25
11:26
03-04-2025
17:25
11:26
Got my Inspire 3 Christmas 22 and battery life has always been amazing but last few months once charge gets to around 60%ish if I receive a message notification (not azm etc) my watch vibrates for the message but then doesn’t stop, at 1st it may vibrate for a minute but as battery drops vibrating won’t stop unless you reset the watch, but can only do this by holding sides of screen to stop the flicker and scrolling quick so it’s a 2 hand job. I’ve tried resetting watch so many times & app but I’m stuck now - any advice? I don’t want to turn off notifications as need them
03-05-2025 03:35
03-05-2025 03:35
Hi, @Mamabear1000, welcome to the community, I would normally recommend restarting your Inspire 3 but note you've already done this. I note your device is almost certainly out of warranty but do suggest you contact "Customer Support" to see if they can help, work through steps one & two and use the contact options at "3".
I hope this helps.
Cheers
Gr4ndp4 | UK
