10-29-2022
22:26
22:24
YojanaFitbit
10-29-2022
22:26
22:24
YojanaFitbit
I am a professional driver and my Fitbit counts steps while I am driving.
22:28
09:22
10-30-2022
22:28
09:22
Hi there, @Tracy927 @dDc22 and @Daisy1972. Nice to see you around the Community Forums. Thanks for sharing the details about the issue with your Inspire 3.
Please not wrist trackers count steps depending on the movement of your arms. Fitbit has worked hard to make sure that our devices do not pick up false steps or activity recordings while driving. Unless you're driving in a car with a very stiff transmission or on bumpy roads, your device should not give you false readings. Also, if you place it in a surface with something vibrating or if you make hard hand movements. You can learn more about how your Fitbit tracks steps by checking the article: How accurate are Fitbit devices?
However, there are 2 ways you can prevent this from happening while you drive:
1. You can plug your tracker into the charging cable while you are driving -- the Fitbit will not count steps while it is charging.
2. You can log the driving manually by following the steps in this article.
Hope that helps.
Best Answer10-29-2022 23:12
10-29-2022 23:12
I believe all FitBits records some steps while driving. Mine does. Its to do with arm movements as often the FitBit takes arm movements as taking a step.
Best Answer10-30-2022 05:18
10-30-2022 05:18
It also counts steps while on a boat ride. I took a boat ride to NY and it logged about 2.5k steps. I couldn't find a "shut down" option in the menu. This was very upsetting because during that time, the app awarded me about 3 achievement badges but they were all false accomplishments.
10-30-2022 05:18
22:28
09:22
10-30-2022
22:28
09:22
Hope that helps.
Best Answer05-06-2023 15:33
05-06-2023 15:33
I have a Fitbit that tracks steps when I move my arm this can't be correct
05-06-2023 15:33
How can I correct this?
Best Answer05-06-2023 17:50
05-06-2023 17:50
Hi @Tracy927, Have you tried ever putting you watch on the clip, in quick settings? It doesn't count steps then. Or maybe even get a clip, to stop it counting steps. You can check out the clip here - https://www.fitbit.com/global/us/products/accessories/inspire3-clip
Best Answer05-09-2023 03:32
05-09-2023 03:32
@Tracy927 You can record previous exercise in the app and record this as 'Driving' and then it will take off all the steps in that time.
