02-25-2023
08:38
12:27
02-25-2023
08:38
12:27
I walked with my wife this morning on her normal 2 mile route. We both have Inspire 3s and started and stopped them at the same time. The GPS connected on both at the start. Our step counts were close and the time was within a second. The GPS reported only about 1.5 miles. My normal running route is 2.5 miles and it's been pretty accurate for my runs. Could it be that inconsistent? Or maybe it lost the signal and was using steps to calculate the distance. Anyone experience accuracy or consistency issues with the GPS?
Best Answer02-26-2023 08:46 - edited 06-12-2023 10:41
@lmacmil Please try these tips:
If the inconvenience persists, please try the following troubleshooting steps:
Best Answer02-25-2023 12:30 - edited 03-16-2024 10:59
Hi there, @lmacmil. Thanks for stopping by in the Community Forums and sharing the details about the inconvenience with your Inspire 3.
Bear in mind that hen you track an activity with GPS, your device calculates your distance using GPS data rather than steps. If you begin moving before you get a GPS signal, your device calculates distance using your steps until GPS connects.
For more information about GPS, see: How do I use GPS on my Fitbit device?
Best Answer02-25-2023 14:39
02-25-2023 14:39
I waited until I got the GPS connected signal before I started my walk. I'll see how it works on my run tomorrow.
Best Answer02-26-2023 05:54
02-26-2023 05:54
@lmacmil Sure thing!
Best Answer02-26-2023 08:36 - edited 02-26-2023 08:45
I ran today and the GPS wouldn't connect at the start and I don't think it ever connected (how can I tell?) Looking back through my runs (I've only had the Fitbit for a week), only one time did my run data show a map, which I assume means the GPS was connected for the entire run. I don't start until I am outdoors so I'm not sure why it's not connecting reliably. Same thing for my wife's (also an Inspire 3). Any suggestions?
Edit. Does the Inspire 3 need a phone to record GPS data? I do not take my phone with me when I run. I assumed that when it says "GPS connected" that there's a built-in GPS. Further reading indicates that it does need the phone. When I saw "GPS connected" I was probably within range of my phone but as soon as I started my run, I lost the connection.
