06-28-2024
10:59
08:31
ManuFitbit
06-28-2024
10:59
08:31
ManuFitbit
My inspire 3 doesn’t track a power walk correctly. Mileage and steps are way off. what to do?
Moderator edit: clarified subject.
07-04-2024 08:16 - edited 07-04-2024 08:30
Welcome to the forums @Lililev.
Thank you for sharing the inquiry regarding your Inspire 3.
Your device calculates your distance using GPS data rather than steps. Please see: How do I use GPS on my Fitbit device?
Try to perform the activity one more time following these steps:
If the inconvenience persists, please try the following troubleshooting steps:
Beside that, confirm that your Inspire is up to date: How do I update my Fitbit device?
07-04-2024 08:56
07-04-2024 08:56
I have found that reported steps can vary depending on how you swing your arms. For me at least, if my arm pivots from my shoulder my step count is substantially less than if it pivots from my elbow. If you are not walking with your phone and using its GPS, then I have found it is best to enter your step length manually. You can calculate it by dividing the actual distance (from the phone GPS or Google maps) by the number of steps. If you walk the same route, best to use an average of several walks since the steps will vary somewhat from day to day. It will never be perfect but it will be close.
