03-14-2026
11:48
12:45
ManuFitbit
03-14-2026
11:48
12:45
ManuFitbit
I’ve had the Inspire 3 for 8 months and I’ve loved it, but the battery seems to be bad. Granted I did leave it on the charger for too long once, but I just went from having to charge it once a week to twice a week. But yesterday I charged it fully, then it was at 30% by the late morning and it completely died again the same day 🤷🏻:female_sign: has anyone seen this before or know if there’s some kind of recall on Inspire 3’s for battery reasons?
Moderator edit: clarified subject.
Best Answer03-14-2026 12:45
03-14-2026 12:45
A warm welcome to the forums @Jrom3.
Thank you for taking the time to share the details regarding the difficulty with your Inspire 3. Thank you for trying to fix it on your own.
Please make sure to follow the steps listed in this help article:
Best Answer04-03-2026 05:19
04-03-2026 05:19
I have noticed the same. Usually charge it once a week then 2-3 Times a week over night. One thing I did around the same time was change too Google account from fitbit. Don`t know if it is related But very suspicios.
Have you solved your battery issue?
Best Answer04-03-2026 08:12
04-03-2026 08:12
It's good to see you participating in the forums @cafebici.
Thank you for taking the time to explain the issue you’re experiencing with the device.
Did you get a chance to try the steps in that help article yet?
Best Answer04-12-2026 01:03
04-12-2026 01:03
My Inspire 3 is about 21 months old. I was still getting about 5 days on a charge with virtually everything minimal or turned off - I prefer getting info from the app (and wish they made a faceless model like the Amazon Halo, which was great). Within the last few weeks, it seemed to start needing charges more frequently. Resetting it didn't help. In the last week, I confirmed it was using about 40% charge per day and needing to be charged about every 2 days. Tonight I monitored the charging and noticed it seemed to stop at 54%. I fiddled with the fit on the charger, wiped the contacts with rubbing alcohol, reset it both off and on the charger, and it finally moved up to 55%. Walked back to the living room and checked the app on my phone, but it already showed it at 100%. I went back to the Fitbit and it showed 100%, as well. I think the problem mine started having recently is that it's thinking it is fully charged well before it gets to 100%. It seemed to go from 73% charged to 100% charged unnaturally fast one time in the last couple of weeks, so that should have been a sign. Now, 55% charged is the new 100% charged, so it makes sense I'm getting about half the time I was getting just a month or so ago from a 'full' charge. Just restarting it on the charger is using 4% of the battery. If it's losing about 10% of it's maximum battery storage per week at this point, it won't last long. Unless there is some other way to reset it or a firmware fix, I'm probably going to have to get another one or try something else. Maybe this is normal for battery failure, but I'm surprised how quickly it is declining.
Best Answer04-13-2026 14:15
04-13-2026 14:15
Too bad to hear this. I spend a whole weekend to think about pros and cons about fitness trackers and decided against expensive smartwatches because of the small battery and therefore short lifetime of these devices that don't have swappable batteries, alas. So I decided to go for a cheaper throw away model and I bought the Inspire 3. But I thought this device would last longer than 2 years if I switch off the screen almost all the time (no auto wake up) because I use smartphone apps connected to HealthConnect in my Android phone. Can other people share their long term experience with the Inspire 3 concerning battery health (SoH)?
