01-14-2026
02:16
16:49
ManuFitbit
01-14-2026
02:16
16:49
ManuFitbit
Hi,
My Fitbit Inspire 3, which I have had exactly 2 years this month, has started to just end my workout half way through. I look at it to check progress on my runs or in the gym and its ended the workout and returned to the home screen. I think this started just after the last update I did and I am definitely not inadvertently pressing the side buttons with my wrist, which has been suggested on other posts. Has anyone else experienced this and if so did you find a solution? At this point it's not even worth wearing it and puts me off buying another Fitbit.
Any help is much appreciated! Thanks!
Moderator edit: clarified subject.
Welcome to the forums @Laura1811.
Thank you for sharing with me this information regarding the difficulty that you are experiencing with Inspire 3.
I'm not sure if you already tried to restart the device as indicated below:
In addition, confirm that you are using the latest version of the device's firmware: Update your Fitbit device
