11-24-2024
14:40
10:21
FatimaFitbit
11-24-2024
14:40
10:21
FatimaFitbit
I got an inspire 3 in September as an update from 2. In the 3 months I've had it the screen has frozen with the light staying on which causes battery to drain quickly at least 5 times. I can plug it in and do a reset but that's not a good answer
Best Answer11-27-2024 10:20
11-27-2024 10:20
Hi there @CAWfit! A warm welcome to the Fitbit Community!
Thank you so much for reporting this situation and for all your efforts.
Have you tried to restart your Inspire 3 with the charging cable?
If not please try to do the following:
Did you check in the Fitbit app if your Inspire 3 needs an update?
I suggest you change the clock face too.
