Inspire 3 has 5 diamond like emblems at tip of display and seems locked out of any other display.
2 REPLIES 2
Hi, @kj2e , I am not sure what that display could be (maybe you could take a picture and post that?).  Meanwhile, it might be worth trying to change the clock face on your Inspire 3 to see if that solves the problem.
The clock face is changed in the app.  The instructions are here .  If that solves your issue you should be able to go back to your previously chosen clock face if you prefer.
It is also always worth giving your Fitbit a restart whenever your Fitbit is not behaving as expected, as a simple restart can shut down any background activities and fix any minor glitches.
I hope this helps.  If not, please do post again with any extra information you can provide.  There is always someone here to help.  Welcome to the Community Forums!
Thanks, ChatGPT had the answer fortunately.
it was a frozen screen and the solution was a hard reset which was accompanied by a iTunes video link. All fixed.
